Hi to all
usually I use Reaper under Windows as DAW for my Guitar.. I will want to move this under ZORIN but ALSA driver can't find Audio Card...
I have a Native Instruments Komplete Audio 1
Can someone help me?
Thanks
Hi to all
Thanks
Hi and welcome to the forum.
Do you know what sound card/cards you have?
Can you open terminal (ctrl+alt+t) and then run alsamixer
in alsamixer, hit [F6] What sound cards are listed ?
A screenshot of your alsamixer display would be good to see.
Hello and welcome to the forum
Can you issue this command and paste the result here?
lsusb
