I see you have the Impish
Repository added to your sources. You only need the Focal Repo.
Please open terminal and run
sudo add-apt-repository --remove 'deb https://dl.winehq.org/wine-builds/ubuntu/ impish main'
sudo apt --fix-broken install
If needed, run the --install recommends winehq-stable command again.
Thanks, It's working
im getting this exact issue since i moved to focal
