Internal mic not working on Zorin 18 – works on Zorin 17
Hi,
Internal microphone is completely silent on:
Zorin OS 18 (live USB)
Ubuntu 25.10 (live USB)
But works perfectly on Zorin OS 17 live USB.
Laptop: ASUS VivoBook
Sound card: HDA Intel PCH – Realtek ALC256
Thanks for any help
It seems as this problem is not yet solved:
You could take a look at this thread and try the solutions that are mentioned there:
Edit: Sorry, on live USB you can't test this options because you need a reboot and the changes aren't saved (except you use a boot-stick with persistence).
Is the Mic at least detected?
Added to /etc/modprobe.d/alsa-base.conf:
options snd-hda-intel model=alc256-asus-aio
Mic now seems to works.
Still testing on full Zorin 18 install.
will update.
it was the right solution, thanks :wink:
Brilliant answer! Took me a long time to find it but worked perfectly. Many thanks.
