I recently asked for help regarding adding a permanent wallpaper and removing the blurry mountain from my login Screen.
After that I am Facing a Problem of my keyboard Hanging (mouse working) and their is a dialogue box type of screen in the center of my screen, Probably the failed to open application one.
I restored everything but after a while the dialogue box screen says failed to open xfce-screenshoter(no such file in directory), But, I purged it and I think the computer is receiving a command to open it continuously. Making it hang.
it fixes after a restart then comes back after IDK something.
This is really frustrating, I created this post in nearly 2 restarts
I have a laptop in which the I disabled the internal keyboard and the external keyboard is ,
wait a minute the internal keyboard is active (problem). Is there a way to permanently stop it. I used the xinput method but it reactivates after a restart.
Maybe you have already seen it as second answer (not hardware one) proposes fix using xinput, but someone commented that it does not hold after a restart, like you discovered. But there is another fix proposed after that, which may be worth a try.
