So, When for some reason I need to suspend my computer, when I turn it on again, the keyboard just stops working and I need do reboot it or shutdown all the time( and I can't login when it happens)
I use caffeine to stop the auto suspend
But when I forget it happens it's annoying
Do you have xorg-input installed?
sudo apt install xserver-xorg-input-all
I don't know yet
I'll check and then I'll reply
Sorry, I didn't reply your comment sooner. But i do have this installed, but the "suspend" keeps deactivating the keyboard
I searched for somethings, but the only I get it's something related to i8042, I updated the grub and I put the the i8042.direct, etc. But it didn't work
Ok, can you try
sudo nano /etc/default/grub
Arrow key down to:
and add the parameter i8042.reset
to it so that it looks exactly like:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash i8042.reset"
Tap ctrl+x to exit, then the y
key to say yes to save, then the enter
key to save and close.
The terminal will revert to normal.
Now, run sudo update-grub
Reboot...
then test after suspend.
