LAN Not working
I just recently upgraded my desktop. New CPU and Mobo.
AMD R7 9800X3D and X870 AORUS ELITE WIFI7
I had MX Linux and didnt bother to reinstall after the upgrade.
Windows is also installed and no problem there. Did not reinstall either.
So Mobo LAN should be working
I would also like to let you guys know that I also have an AX3000 installed which I am still using. No, I am not using the WIFI 7 built in with the MOBO just yet.
This information may or may not be important. I just wanna put it here. Sorry for making this thread longer.
So MX Linux, no LAN.
Then I decided to install Zorin OS. During the installation, connection is through the Wifi. I knew right there that LAN still isn't working but hey, Zorin might install the driver.
Still no.
So any way I could make my LAN working with this Motherboard?
I got it working.
So I have the Realtek RTL8125B and manual installation is needed.
git clone https://github.com/awesometic/realtek-r8125-dkms.git
sudo ./dkms-install.sh
If anyone needs this.
