Language not converting
I am using ibus avro which converts english language to bangla language(local) , i am writing a script in google docs, few words became converted then rest of the words became unfinished (which dont convert to english) , how to fix this problem? it fixes after restating but it occurs again and again
There have been a couple of known bugs with this package, so the first thing I would recommend testing is a simple:
sudo apt install --reinstall ibus-avro
Followed by a full reboot and test.
If that does not do it, the candidate selections json file might be corrupted. Remove it:
rm ~/.candidate-selections.json
Then reboot and test...
not working , fixes for a short period
I have continued looking into this, but not using ibus-avro myself, my own experience is limited. Searching the web, I am finding little.
But I have not given up.
The above fixes it for a short period - but then it reverts?
this may be an important detail.
There are a few pointers here:
another ques, i have installed zorin 17 beta , when the main version release, should I have to download iso file again ? and install that?
No. The Z17 Core Beta should update to the production version of Z17 Core.
No need to download the .iso, but I would do that anyhow as a backup source.
