Are Secure Boot and Fast Boot in BIOS disabled? Did You tried Pulse Audio Volume Control? It is a Tool for set up Audio Input and Output. You can install it with the Command sudo apt install pavucontrol in the Terminal. When installed, open it and check the Configuration and Output Tabs for Audio Profiles and Options.
You could try it with switching to Xorg. To do that, go to the Login Screen. Click there on Your Profile so that the Password Field appears. when it is appeared, You should see a Gear Icon in the bottom right Corner. Click on it and choose the Option ''Zorin Desktop on Xorg'' and then log in.
I think my best hope is to install a newer kernel, the problem is I can't install form the mainline repository as I can't disable secure boot in the bios as 2 things happen-
windows 11 won't allow me to login
Booting into Zorin the desktop config and installed programs gets destroyed.
The main line depository I found in in another thread can't be installed.
So can someone suggest a different repository where I can try a newer kernel that can be used with secure boot enabled ?
Thanks again to everyone.
The bios on this machine is like nothing I've ever seen before.
So I've come to the conclusion it's a kernel issue.
When are we likely to see a kernel update to support newer hardware?
Can't say I'm not disappointed, also that the usb audio is also flakey with bluetooth headphones, yes I've tried Pulse audio but nothing improves with that or any other fix I've come across.
Usually we see new kernels, whenever there is a new OS update, for which we just had one, with OS 18.1. So, not likely to see a newer kernel, until OS 18.2.
You could do a fresh install of Zorin without secure boot enabled and then install a mainline kernel but that would mean to change BIOS secure boot settings each time you switch between Linux and Windows.
Another option is to sign the mainline or liquorix kernel yourself. But unfortunately I can't help you with this.
You're probably better off using a distribution based on a newer kernel at the moment. Often the very latest hardware isn't fully supported by any LTS distributions.
@NickS Yes I tried the older kernel available from the advanced boot menu and it's the same.
@Forpli I tried booting into Zorin with secure boot disabled and it wrecked the installation!
I've also tried most popular distros and i didn't really like them although with the latest Ubuntu everything worked out of the box and I paid for Zorin pro.
Can anyone point me to a a newer kernel and the method for self signing. I am willing to experiment with the internal SSD fully backed up with RescueZilla.
AFAIK I know I followed the instructions fully but various output still shows no sound card found. I did log it all to a txt file but I can't upload it here.
At one point I had a problem with the driver not binding to my sound card but, if I recall, it had to do with acpi which I had previously set to off in order to get beyond the black screen/hanging after booting issues. You presumably haven't made any special changes to your acpi.
