After Upgrade to Zorin 16, my Dell's Battery works 2 hours less than before
Hi and welcome to the forum
Your posting has been moved to the similar thread to concentrate our volunteers effort.
OK Got it.
Just, Do we have some news about Battery?
81% and 1h:22min.. impossible
According to the posting nos. 12 and 14, either change the NVidia card settings (if any) or clean install fixed the issue.
what do you mean in " clean install fixed the issue " ?
Wipe entire drive and start over from scratch.
Thank You! everything works fine
Glad to hear that.
Did you re-install OS?
Or change the NVidia settings?
VGA compatible controller: Intel Corporation HD Graphics 5500
VGA need more resources.
here is mine, at this moment
Thanks for this report
I am sure it will help the future visitors to this forum having a similar issue
So am I understanding correctly, you now have an approximate maximum battery percentage, to last up to 5-hours on a fully charged battery now? If this is true, that is not bad! Thats enough time to watch 2 movies, or play a heck of a lot of rounds of solitaire.
