mijn installatie wordt steeds gestopt door melding 256
First, can you check the pre-installation advice here: Before you install
Which tool are you using to create your ZorinOS installation USB stick?
Sorry I first thought your post referred to ZorinOS installation.
Is "Le geant du traffic" a game?
What did you try to install? Zorin OS or an app or game?
Could You offer more Details please? A Description of what You have done and what You want to reach?
Dank jullie wel Achteraf bleek dat het spel stuk was
I assume you've tried to use Proton, unless you say the game is so broken from the developer, that nothing will work?
