I can't find it if is there ...
I am also flying by the seat of my pants, here. This is not something I have ever done, before.
However, reading that workaround link above, it looks like this rec_keymaps portion only applies if you created your own custom keymap.
I can only suggest at this point rebooting and testing - with all your fingers and toes crossed. Given that it references kernels well below the 5.11 version currently in use, I will admit I am not very optimistic...
If it fails to help you, then I am not sure of a solution, either.
I did a cold boot and despite fingers crossed it hasn't changed.
I am thinking there is obviously some mapping going on because of the ability to control the volume ... it shows the IR is working just not quite right.
Thanks for your help I really appreciate it, perhaps someone else might have some more ideas?
I was surprised how easy it was to get Zorin installed on the macmini. Everything apart from the IR control worked out of the box. In fact I prefer Linux over macos ....
This is a bit of an experiment so I might even try a clean reinstall ...
Regards
