antes de vir para o zorin os usava o motrix como gerenciador de dowloads mais infelismente estou temdo problemas ao executar o app
Uploading: image.png…
Uploading: Captura de tela de 2025-12-29 22-12-01.png…
Olá, suspeito que o problema possa estar relacionado com a versão snap/flatpak/App image instalada, uma vez que estas versões são executadas externamente ao sistema. Seria melhor removê-la e instalar a versão .deb a partir daqui:
[English:
Hi, I suspect the issue might be if you have either the snap/flatpak/App image version installed as these versions run external to the system. You would be better to remove it and install the .deb version from here:
@anderson Your images seem to be missing from your post. Maybe you did not give them enough time to upload.
EDIT: Just seen Swarf's reply. I agree with his suggestion to try the .deb version.
