Hi all!
I made this small script to help newbies install WINE, Winetricks, Lutris and other gaming patches without commandline! Feedback welcome
Learned something new about shell scripting, didn't know about the zenity command.
Although I'm curious about the "please enter your password before installation", when I try it in my computer I don't see any input available so how could I provide it? And is it passed in automatically to the argument list?
If it doesn't ask for password and still works, you have nothing to worry about It's possible that I missed something, I'll test the script on a fresh installation
The first command is for a sudo, so it should prompt for a password. If it doesn't it might be because you had just utilized a sudo command prior to that (its happened to me, though not often). As many are required in the script you should see a password request at least once.
I did not run the script, I just read the first couple of lines and was curious about how that zenity
command works as I did not know about it.
When I copy and paste this line of the script in my terminal and hit enter, I get a window prompt with that text. But it looks like a simple notification, there is no text field or any other indicator that I'm supposed to type in something in it.
zenity --info --title="Before Starting the Installation" --text="Please enter your password" --no-wrap
That's what got me wondering how's the script listening to user input? Or is it really just a notification message telling me that I need to run the script as sudo?
It's just a dialog, nothing more
Hello,
Thanks for your work.
What if there is a problem and one would like to remove the script package?
How would one do that?
Thanks.
Steve
You can uninstall Wine, Lutris, and Winetricks easily with apt.
