Making BibleTime More Accessible with Proposed solutions
Hello: I have been trying to figure out how to make BibleTime work better for those of us with visual impairments, and I have found a workaround.
  1. Use Speech note and do the following: Go to settings in the hamburger menu (Shortcut key for this is uncertain at this time as I am new to this one). I then select English EN then Select Text-to-Speech, then pick a voice.
  2. Download Fast Reader from the Software store and install it. Startup Fast Reader.
    3.3. With BibleTime open, copy your text by mousing over it. Not sure how to do this with the arrrow keys, because when you press the SHIFT key and the arrow keys, the text scrolls, so there must be another solution to copying and selecting text to copy rather than having to mouse over. I have been able to do this as best as possible to be able to read a desired selection of text from eithe r acommentary or devotional, then
Paste it into BOTH first Speech Note, then paste it into Fast Reader. Now right click the speech Note app window and click read all. Then immediately switch back to Fast reader. Now use your number pad 2, 5 or 8 keys, or up / down arrows to read the text, whichever you prefer. Using this along with the Zoom function of Orca, you can magnify the text and listen as Speech note reads your selection aloud to you and you can arrow through the text as you hear the text spoken.
My proposal is: use this idea in Fast Reader, as it already has a dark mode, and create a key binding for that. Attach this key binding. My proposition is Ctrl Alt R for Read Text aloud. Instead of you having to arrow through the text as the Speech note reads it to you, which admitedly is better quality, is there a way to integrate these two together to make a good reader program for those of us who would like to read the text and hear it spoken as it goes past us word by word much like in fas reader. Listening to the text and reading it will also heop us to retain what we hear better. Can someone create this program?
Hi.
There are numerous pdf versions available:
" Multiple free PDF versions of the Bible are available online, including the King James Version (KJV) , New International Version (NIV) , New Revised Standard Version (NRSV) , and New Living Translation (NLT) .
  • The King James Version is available as a public domain PDF with a table of contents and bookmarks at holybooks.com or davince.com .
  • The New Revised Standard Version can be downloaded from archive.org .
  • The New Living Translation (NLT) PDF has been shared via download.sabda.org/mobile/pdf/NLT.pdf , though access may vary.
  • The New International Version (NIV) and other translations like the Amplified Bible and Good News Bible are listed for download on biblesfree.org and csbible.com .
These resources allow users to read, print, or study the Bible offline without cost.
Once you have the correct one you can use Okular which can magnify to over 1,000 per cent.
Then you need to add Okular backends for speech.
I only managed to get speech working using a package called 'flite' and only got it working on Feren OS.
I did not need 'flite' in the end. If you do decide to install Okular, don't use the Software Channel/Store as it only has Snap available - APT is listed in the drop-down arrow but it does not work. I tried to uninstall it but it would not let me and searching for Okular just took me back to the Software Channel entry.
Install Sunaptic via the Terminal with:
sudo apt install synaptic
Once installed, launch it and you will be asked for your login password to elevate you to 'root' (administrator). Use the Search Button and look for okular.
Install it.
Once installed I found it already has 'speechd' working in the back end. You can read current page or the whole document or if you want to use the 'Selection' tool, you can highlight a section, right-click and choose 'speak text/selection'. I forgot to include that in the video which I created here:
I was running ZorinOS 18 Core as a VM and unfortunately it has not picked up the speech that I could hear. I can redo it if you wish.
Just to add, Okular has a text extraction tool so you can select text and copy into your preferred Text Processor pre-set to the correct enlarged font style user is accustomed to. LibreOffice Writer is the best option for screenreader compatibility. Sadly SoftMaker Office does not work with Orca.
