Hello,
I have Asus vivobook go 14 AMD Ryzen 3, installed with mediatek mt7902 wifi 6e chip. In my laptop wifi and bluetooth is not working. Can anyone please help me how to fix the issue.
Thank You.
Hello,
Thank You.
Did You take a Look in the ''Additional Drivers'' Tab in Software & Updates if there is a Driver offered?
Could You post the Output of the Terminal Command sudo lshw -C network please? it gives an Overview of Your Network Stuff.
I only found posts that this Mediatek MT7902 doesn't work in linux and there are no drivers available yet.
You could only replace your WLAN/Bluetooth card or use a linux supported USB Wifi-Bluetooth-Dongle.
If your computer allows it, you could look inside and see if the wifi module is replacable. I've been meaning to replace the chip in my laptop with a better supported one that doesn't suffer so many drops. As long as it's not soldered on, it's a relatively quick and painless change, and the chips themselves are relatively cheap to get as well.
