Minimal installation
Is it possible to make a minimal installation, I mean without any extra program as Libreoffice, Evolution, Calendar etc?
Hi, welcome to Zorin OS!
Not at the moment, no. If you want to make the installation a little faster make sure to disable the option to download updates during the install. Then, you can uninstall whatever programs you don't want, and then run the software updater.
Keep in mind, however, that many pre-installed programs have dependencies on core system libraries. Some you can remove safely e.g., LibreOffice, but others not so much and is worth looking into them individually.
Not on Core and Lite but as far as I know there should be a Minimal Installation Option in the Zorin Pro Version. Maybe someone with Zorin Pro could confirm that?
