I come to little problem. In display settings there is no option to mirror display. When I plug the external monitor, it shows only wallpaper but no icons. Testing other distros, I had the option to mirror, but did not work well. While mirror the external monitor will display all, but laptop will go blank.Without the external monitor plug in, I have option Join displa mirror and single displa, but when I plug the external, the mirror option is gone
Pretty sure I had the option with my wife’s old Z15 core install and it should work on Z16.
Maybe this helps: Cannot mirror display
