Mount Other Location on startup/login
I have a tower case computer. Within it I have multiple drives. Zorin OS 17.1 Pro is on my main drive. Backups point to a second drive which appears in Files within Other Locations.
Backups are scheduled once a week but it fails because the secondary internal drive is not mounted. How can I have Zorin mount the secondary drive on startup/login so that I don't have to do this manually.
Thank you
Use Discs app.
Select the partition you want to mount at startup, click the gear, then "Edit mount options". Check the option "Mount when starting with the system".
Screens (in portuguese)
This worked thank you!
