Hi All Pronouns
I am having weird issues with copy paste in Zorin. I find it difficult to easily select words and copy. I find getting all the word difficult and when i miss and try to deselect i have significant issues i must refresh page a lot of the time. I know it sounds weird, but it is annoying
I seem to have similar trouble - on all browsers. It seems like it likes to Auto-Highlight what I am not trying to highlight.
Can you clarify a few things, please:
- Do you have the same issue on all applications including text editor and input entry widgets?
- Does it seem like the mouse cursor is moving too fast?
- Are you using a gaming mouse, trackball or otherwise unusual mouse?
I think i found the culprit it was Edge menu suggester when you select a word it has several functions like copy and lookup on bing but it never showed due to my colour scheme i turned it off now:)
