I've just installed 7d2D on a Linux Zorin OS with 16Mb of Ram, an integrated Nvidia graphics card and an Intel i5 3.4GHz processor.
After a lot of tweaking the graphics are amazing...
But I'm having a problem with movement. When I press any of the keys (ie: W, S, Shift etc) to walk or run the character continues walking even though I've let go off the keys. It means that I cannot pick anything up or fight. It almost seems like there's a lag in the memory as it takes a while to register that iv'e taken my finger off the keys.
I've looked everywhere for a solution but to no avail.
Has anyone had this problem and have you been able to fix it?
PS: It worked perfectly on a Windows 10 OS with the same specs previously.
I've uninstalled everything to do with Steam and 7D2D, reinstalled using the DEB file, no luck. Then installed it again using the flatpack, still no luck.
I've googled it, YouTubed it but I still haven't found a solution. Grrr
