I do not understand this statement.
sry my english is not so good , i meant my wifi is not connected to my pc . how would i check the ipv4 or ipv6 thing
Are you connecting by ethernet or hotspot?
I can only speak one language, so I can hardly complain about others speaking more than one.
im connected to internet via usb cable
Usually - a USB connected net is for a Wifi Adapter...
usb tethering
if you find any solution let me know
Did you see @337harvey 's post above?
Do you have 'Metered Connection' enabled in the network settings?
yo! it worked for me. thanks buddy @PlumpKibbles and thanks @Aravisian too
No worries!
By the way - if you're using Android, you can sling internet over Bluetooth as well without a 'hotspot' per say. Should be under 'Other wireless settings'. Great for the car, too!
