I have trouble using my laptop keyboard due to loss of nerve sensation in my fingers. When I was using MS Windows I used the on-screen keyboard and that worked well. When I switched to ZorinOS I discovered that the on-screen keyboard was fairly difficult to use. I found U+ Input Pad and it is also difficult to use and takes up a lot of the screen but at least I can move it around the screen. I would really like to find an on-screen keyboard for ZorinOS that is compact and has a word-prediction feature. Does anyone know if this exists and where I can find it? Thank you!
You can try Onboard
sudo apt install onboard
Marked solution. 95
