Hi,
has anyone had this issue and possibly a solution?
After a computer start the network connection is delayed for a min of 30 secs to 60 seconds on ethernet (no wifi).
This happens whether I login or not. I have contacted the router hardware vendor to see what they know without success (they analysed the logs)
So far this happened with ZorinOS 16 (only after a year of using it) and 17. After a couple of OS reinstalls and driver updates (attempts) this is still an issue.
Have you checked for any breakages in the cable/tried a different ethernet cable? Tried a different port on the router? Is the router close or far away from the computer? Is the ethernet port on the computer part of the motherboard? Sometimes driver updates are issued by motherboard manufacturers, but you've probably guessed already it wilk need Windows.
This article may help:
Lastly, have you disabled IPv6 in Network settings?
[Footnote: When I was an IT Contractor I met a very knowledgeable guy who never got round to lending me a book that explained the physics of networks being slow as copper takes 30 seconds to warm up.]
The thought occurred about the board being broken just never had that before; tried the driver install to no avail.
Have restarted the router multiple times since.
