Hier die Fehlermeldung in deutsch:
Verbindung gescheitert - Aktivierung der Netzwerkverbindung ist gescheitert.
in english:
The following error message keeps appearing on my computer:
Connection failed β Activation of the network connection failed.
I have checked all network settings and found no errors.
Does anyone have any ideas?
Nevertheless, everything works perfectly.
Is this on Wifi?
Do you see a "?" icon for WiFi on your taskbar?
If WiFi is working OK regardless of that error message. Try this.
Go to Settings>Privacy and toggle "connectivity checking" switch.
I have no idea what exactly happened, but now everything is fine. Thank you so much!
Unfortunately, it didn't work after all
Network Connection Activation Failed
The "Activation of Network Connection Failed" error in Ubuntu 22.04 typically indicates a failure to connect to a network due to configuration or hardware issues. Common causes include incorrect network settings, driver issues, or hardware incompatibilities.23
To resolve this issue, you can try the following steps:
- Disable and Enable the Network Connection : This can reset the network settings and allow the system to reconnect with the router and update its IP or DNS settings.2
- Check and Modify Network Manager Configuration : Ensure that the renderer is NetworkManager in the
/etc/netplan/
directory. Verify the /usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf
file to ensure Ethernet, WiFi, and WireGuard are set as exceptions.34
- Update Your Linux Kernel : Updating the kernel can fix bugs, improve performance, and solve hardware compatibility issues that may cause network problems.5
- Blacklist Other Communication Devices : Blacklisting Bluetooth or additional network adapters can prevent interference with your primary network connection.2
- Remove Unused Bluetooth Devices : Removing old paired devices can reset the Bluetooth stack and help your system focus on new connections.2
- Disable Fast Boot : Disabling Fast Boot in Windows can fix issues where Linux cannot connect to the network due to hardware being in hibernation.2
- Disable Connect Automatically Option : Turning off the "Connect Automatically" option for specific networks can prevent failed connection attempts and give you more control over network selection.2
- Check System Clock : Ensuring the system clock is correct is crucial for SSL certificate validation, which can fix connection problems caused by a mismatch.23
- Reinstall Network Manager : Corrupt files or settings in Network Manager can cause network connection issues. Reinstalling it can restore the systemβs default network management.23
- Disable Power Management : Disabling power management can prevent the network card from being turned off to save power, ensuring a stable connection.23
If these steps do not resolve the issue, consider reinstalling your Linux distribution or seeking further assistance from community forums.234+4
appuals.com
Fix: Activation of Network Connection Failed in Linux
nixcraft.com
Ubuntu Error: Connection activation failed: Connection is not available on device because device is strictly unmanaged - Linux - nixCraft Linux/Unix Forum
reddit.com
r/Windscribe on Reddit: Ubuntu 'activation of network connection failed' error.
forum.zorin.com
Activation of network connection failed everytime - General Help - Zorin Forum
reddit.com
"Activation of Network Connection Failed" Ubuntu 24.04
unix.stackexchange.com
ubuntu -
Also, if your connection to the network, involves a router, make sure you power cycle the router. If using a wired connection, sometimes un-plugging/re-plugging the ethernet cable is the fix.
