New hard drive for old laptop - booting issue
It boots up directly from the HD - no boot screen offered - available - legacy/uefi boot is the booting choice - has always been, but could call up grub or refind in the past - now nada - any ideas? It is booting though straight into Zorin 17 log in screen, but would like to fix it. Thanks ahead of time - lol
Are you dual booting with another OS or Distro?
Is your question that you want the Grub Menu to show always?
You can
sudo nano /etc/default/grub
and change the style from =hidden to =menu
and ensure that the timeout is set to 10 (minimum 5.
Once any changes are made, tap ctl+o to overwrite, then enter to save current configuration. Tap ctl+x to exit the editor.
Now, you must run
sudo update-grub
Thank you - from there it all worked and I could add to it. will be repeating this for the newer but weaker - sigh - old Del - was supposed to be better - a bad sale to me - but still it's next as well. New SSDs all around to optimize the speed they can attain. Both ae still faster than an i3 - tg. Again thank you.
Oh yes - also this old Del 7720 16gb, 2+2T ssd now boots in just a few seconds - that silly 4 core processor is now as quick as the i5 Beelink Pro running Zorin 16.3.
Very Satisfied.
