NEWB: Installing "libxcb-cursor library"
I don't know what a library is or how to find it or install it. An app I downloaded says I need it in order to install the app. Help?
Are you running Zorin 18?
Do you need libxcb-cursor0?
You can install it with
sudo apt install libxcb-cursor0
If you need the developer package, it is
sudo apt install libxcb-cursor-dev
BOOM! That worked. THANK YOU!!!
