I've been trying to use Zorin's built-in Night Light feature, but the automatic Sunset to Sunrise times are completely wrong. The sunset to sunrise time currently in my city is from around 5:45pm to around 6:45am, but Zorin is set at 8:13pm to 9:25am (in the Toronto timezone).
I messed around with it a lot and found that it was inaccurate for pretty much any timezone I put it in. It doesn't seem to factor in latitude at all (the Toronto timezone has the same sunset and sunrise times as Iqaluit, both of which are UTC -5, but are in very different latitudes, for example). The closest to accurate it gets is around the Los Angeles time zone, where the differences between the actual times and the times night light gives are less than an hour, but still not exactly correct. The farther you get from this area, the less accurate it gets (the sunset/sunrise times in asia make no sense at all)
I duel boot Windows, and my Bios clock was wrong, but I fixed it, which had no effect on this (my time on Windows is also accurate). My location services are on, my timezone is accurate. I just upgraded to Zorin 18 Pro, but this problem was also present before I upgraded, I'm only now deciding to deal with it properly. Here's my system information:
I'm not sure if you can setup coordinates for the integrated nightlight function. In Redshift you are able to. Maybe that could also help to get the correct times for the automatic nightlight switcher.
Thanks for all the replies y'all. To be clear, I can manually set the sunset and sunrise times, that works fine, it's just a pain because I'd need to reset it every week or so as the nights get shorter or longer over the course of the year, and presumably if the automatic sunset/sunrise time function worked, I wouldn't need to bother with that.
I set the time in the terminal using timedatectl and made sure the Windows time was synced just now, it doesn't seem to have affected anything.
I will also say: while messing around with this (and attempting to get redshift to work as an alternative) I noticed that some parts of my system seem to think I am in Calgary (I am in a city in Canada, but nowhere near Calgary). Redshift-gtk automatically assumes my coordinates are in Calgary, and also the weather app thinks I'm in Calgary when I look at the popup from the taskbar...
