Marked solution. 237
This solved it for me finally. Plus I set the time to manual and rebooted. Tnx. Not exactly intuitive.
Hello
I just wanted to share my solution. On my end it was not Zorin's nightmode itself or even redshift (since it also wasn't working first on my end). The issue had something to do with the nvidia drivers.
So, I followed a guide and installed recommended drivers automaticly by running:
sudo ubuntu-drivers autoinstall
After a quick restart after this installation Zorin's nightmode and redshift started working! Well, now I can uninstall redshift since the build-in night mode is working again.
Maybe this could help out?
As I wrote before, the night light setting started working again correctly.
But I'll definitely try what you suggest about the drivers, thank you!
