No sound (on laptop)
Trying to find a Linux version for sound drivers (as mentioned in first post). It looks like there are no native Linux drivers for those (or these?).
https://thesofproject.github.io/latest/getting_started/intel_debug/introduction.html
So what's going on here? I'm reading it and I'm a bit confused.
Here under some ppl found a solution.
That's interesting, I don't have an option in modprobe.d that says options snd-intel-dspcfg at all.
What is your model laptop maybe i can find more info with research your problem.
Samsung 950XCJ/951XCJ/950XCR (Galaxy Book Ion) as far as what I saw on Neofetch.
Did you tried that solution?
Restarting Ubuntu means it always resets the audio output device to "Built in audio" but I want the audio output to stay in "HDMI / DisplayPort" How do I resolve this issue?
Unfortunately this fix was only tested on Panasonic Toughbooks, so we cannot guarantee that it will work on any other computers.
Here on some models samsung.
https://www.reddit.com/r/Ubuntu/comments/g9jka3/ubuntu_on_laptop_sound_problem_help_me/
galaxy book2 pro audio problem | Linux.org here this link problem is solved
I tried following the link on this post and still the same thing.
My microphone is connected with port USB. You have a laptop ten propably you get some chip Realtek or another type microphone. Your laptop using SoC chip? I have the same problem on motherboard no sound on another pc. I using a single audio adapter dongle. That's is problem on Linux and companies they are greed and don't wrote drivers. I wondering what type chip you have then we know if exist some solutions.
I reading many forums propably you have alc298 the same chip what my motherboard on another pc.
It seems all you need to do is install the sof-firmware package and reboot.
Here on this link under is solution
drivers - Sound card not detected - Ubuntu 20.04 - sof-audio-pci - Ask Ubuntu but i don't know if working for you.
I tried the lower link and it still doesn't play sound, and now it's not detecting the microphone. On the bright side though, it's saying built in speakers instead of sof-hda-dsp.
No drivers this what i can sayed. The samsung galaxy laptops are diffrent with components. Propably for your version a laptop the drivers linux doesn't exist.
I think this really should be in the current kernel in use by Zorin OS at this time.
@Turtle11 , can you please try this tip found here:
And see if that helps?
If not, we may need to try elevating you to a higher kernel.
this is the speakers what @Turtle11 using.
Same issue. However, when I tried to do this, my thing was showing Realtek ALC298 and not ALC256.
Updating the kernel is very risky, I know from experience because I tried following a guide to update to kernel 5.15 and I encountered a black screen upon startup and I was forced to reinstall Zorin. But if you're saying this the only option left...
I've changed speakers recently.
https://bugzilla.kernel.org/show_bug.cgi?id=208555
And now Spotify doesn't play sound.
Yes. The changes in grub - did you back the old settings grub before link what you uesed?
