No Swap partition
I have been using Zorin since the 15 version, no problem what so ever. But still I have a question - When I install the system I never use a swap partition, maybe because of the 16GB (2x 8GB memory i have installed). Instead after the installation there is a file on my root named "swapfile" aprox 2gb in size. - Is this usual and can it cause (security) problems or......
Hi and welcome to the forum :slight_smile:
It is normal to have swapfile. It is a part of the OS.
I agree, that its normal, but the installer doesn't seem to make the same choice for everyone. If I recall from the screenshot I just posted yesterday, Gparted showed no SWAP partition on my OS. Which could be due to the fact that Zorin auto detected I was using an SSD drive, and knew not to ruin it with a SWAP partition lol.
Swap file and swap partition are different things. Neither pose any serious security risk... Zorin OS creates a Swap File by default.
A swap file exists on the same partition as your Zorin OS installation.
A swap partition is on a separate partition - used for Hibernate, for example, in order to isolate it from that actions of the Zorin OS partition.
You can remove it if you think you don't need it.
29 posts were split to a new topic: SSD/HDD lifepan, RAM and horses
