No WiFi Adapter Found - Lenovo Laptop
Doesn't work, i have the same error.
Did you download and extract the files to Documents?
Or are they in Downloads?
sudo cp ~/Downloads/git/rtw89/rtw8852a_fw.bin /lib/firmware/rtw89
You can see how that is working...:
sudo for Privileges, cp to copy, path/with/the/file path/that/is/the/destination/for/file
The folder rtw89 has path /home/zartilas
update: i Transferred the folder to Documents and i running the command [sudo cp ~/Downloads/rtw89/rtw8852a_fw.bin /lib/firmware/rtw89] again. I haven't any error.
Follow the proper path to the file on your computer.
Ok, i ran this commands :
sudo cp ~/Documents/rtw89/rtw8852a_fw.bin /lib/firmware/rtw89
sudo modprobe -r rtw89pci
sudo modprobe rtw89pci
modprobe: ERROR: could not insert 'rtw89pci': Operation not permitted
and i have error only in the last.
Ok, I need to leave for an hour or so- hopefully @anon96359095 is still around to continue assistance if you are in a hurry...
@zartilas,
The solution is to disable secure boot. I see your running Zorin in dual boot so i assume your using Windows as well.
Firstly check if SecureBoot is enabled on Zorin OS.
Install mokutil sudo apt-get install mokutil
and check the status of SecureBoot mokutil --sb-state
In case it is enabled run command sudo mokutil --disable-validation
OR
Turn off secure boot in your bios.
(Facepalm)
I didn't even think of it...
Oops.
Same here...
Michel +1 vs Moderators 0
That worked. Thank you.
