No WiFi connection menu Zorin 16 Core
Hello, I'm new here and i Linux world so sorry for maybe lame question.
So I've got HP Stream 13
I've installed today Zorin Os 16 Core. Everything works fine but I don't have in settings and menu in right down corner any informations about WiFi connection. So for now this laptop got only offline mode and it hasn't got Ethernet connection...
Can you please post the terminal output for
sudo lshw -C network
You can take a photo of the screen and post it here if that helps transfer the information.
Edit
I updated OS via cable from my mobile phone but nothing changed
While connected via mobile phone, can you try:
sudo apt update
sudo apt install firmware-b43-installer b43-fwcutter bcmwl-kernel-source
Be sure secure boot is disabled in the bios prior to installing Aravisian's recommendations, or they will fail as well.
I disabled secure boot as said @337harvey and then used terminal as said @Aravisian . Now Everything works fine. Thank You guys for your time and help!
Topic can be closed now.
