Oh yes, thanks for reminding me.
So far, everything looks good. The last thing- kill that pop up.
Please run
sudo nano /etc/update-manager/release-upgrades
At the very bottom, change the prompt to never
It should look like:
Prompt=never
Then ctrl+x, y, enter
If you prefer, you can use sed to do it on one command:
sudo sed -i 's/Prompt=.*/Prompt=never/' /etc/update-manager/release-upgrades
Reboot.
dualipa:
Should I Upgrade, Now?
You can run
sudo apt upgrade
Or
sudo apt dist-upgrade
But please do not yet run the GUI upgrader Tool.
Zorin OS does not yet have any Direct Upgrade option and Zorin OS 17 is not anywhere near release.
So... If you perform a release Upgrade at this time, it will break Zorin OS. You will have to reinstall the Operating System.
Can you please open the Settings app from the App Menu
Then navigate to Notifications. Move to the Applications tab.
Please post a screenshot of that screen.
Do not have the screenshot plugin, removed it after seeing one post on the forum. But, everything here is on urgent and active. Should I turn Something OFF?
Tagging @AZorin and @zorink to review unusual activity.
Partly, this is due to the prospect that the release-upgrades prompt is set to never and yet, the system is offering to upgrade the OS to Ubuntu 22.04.
dualipa
September 24, 2022, 2:32am
47
I suppose not, I am now getting the prompt to restart now, Should I?
eid
September 24, 2022, 2:54am
49
u can type history in terminal to list all commands which one of them may caused that error, and print the result here
dualipa
September 24, 2022, 3:01am
50
The Last thing before the Error,
589 sudo apt install xfdashboard
590 sudo apt-get install -y libnotify-dev
591 sudo apt purge xfdashboard
592 apt-get
593 sudo apt update
594 sudo apt upgrade
595 sudo apt --fix-broken install
596 sudo apt upgrade
597 sudo apt --fix-broken install
598 sudo apt-get -f
599 sudo apt upgrade
600 sudo apt --fix-broken install
601 inxi
602 neofetch
603 sudo apt remove 5.15.0-43
604 sudo apt autoremove
605 sudo apt --fix-broken isntall
606 sudo apt --fix-broken install
607 apt list --installed | grep -i linux-image
608 "dpkg --configure -a --abort-after=99999"
609 dpkg --configure -a --abort-after=99999
610 sudo dpkg --configure -a --abort-after=99999
611 sudo rm /etc/grub.d/35_fwupd
612 sudo apt upgrade
613 suo apt --fix-broken install
614 sudo apt --fix-broken install
615 sudo apt-get purge linux-image-5.15.0-43-generic
616 sudo apt-get clean
617 sudo apt autoclean
618 sudo apt autoremove
619 sudo apt-get install -f
620 sudo killall apt apt-get
621 software-propeties-gtk
622 software-properties-gtk
623 sudo apt clean
624 sudo apt autoclean
625 sudoaptatoremove
626 sudo apt autoremove
627 sudo apt -f install
628 sudo apt remove linux-image-unsigned-5.15.0-43-generic linux-image-5.15.0-43-generic linux-headers-5.15.0-43-generic linux-modules-5.15.0-43-generic linux-modules-extra-5.15.0-43-generic
629 sudo apt autoremove
630 sudo apt update
631 sudo apt upgrade
632 sudo dpkg --configure -a
633 sudp apt install -f
634 sudo apt install -f
635 sudo apt remove linux-image-unsigned-5.15.0-43-generic
636 sudo apt update
637 sudo apt remove --purge grub-pc grub-common
638 sudo apt install grub-pc grub-common
639 sudo update-grub
640 sudo apt clean && sudo apt autoremove
641 sudo dpkg --configure -a
642 sudo apt --fix-broken install
643 sudo nano /etc/default/grub
644 /boot/grub/grub.cfg
645 sudo /boot/grub/grub.cfg
646 sudo nano /boot/grub/grub.cfg
647 sudo nano /etc/default/grub
648 sudo update-grub
649 sudo dpkg --configure -a
650 sudo apt --fix-broken install
651 sudo apt update
652 sudo nano /etc/update-manager/release-upgrades
653 sudo apt upgrade
654 history
dualipa
September 24, 2022, 9:23am
51
I removed this line, Cause I no longer use Hibernate. But, I Started to have boot problem. So, I used the advanced options for Zorin booted up and then added the line back. But, it gave me more boot problems. Took me to black command line. I Used advanced options again to log in but, What should I Do?
dualipa
September 24, 2022, 12:13pm
52
Installing Boot Repair Fixed each and every problem for me
sudo apt install boot-repair
boot-repair
Thank You @Aravisian , @anon6471198 and @eid for such a professional and personnel support
All the Problems have been Solved
The support volunteers really are quite amazing. And this is such an understatement.
system
Closed
December 23, 2022, 9:03pm
54
