The problem is that sometimes the numbers don't work, regardless of whether I use the NUM pad or the number/character combination. As soon as I press several times, a number appears at some point.
Sometimes all numbers except a certain number work.
What could be the reason? I have already cleaned everything
I rule out a hardware error, as it occurs with the NUMPAD and the combination numbers at the same time.
OS: Linux Zorin 17OS (but also occurs in Windows 11)
