hi this isnt about zorin but if you have any idea about windows 10 i need your help. it wont let me download things that arnt from the windows app store and i have tried to turn that off but i havent got the option to in settings do you have any idea?
So… definately not Zorin. Try https://superuser.com/
Will it let you download any files? or do you mean it wont let you install *.exe files?
If you can download, but not install, check to see if you have admin rights.
Also, as with anything, (if you haven’t) try rebooting.
As noted, this is not relevant to Zorin. Closing thread.
