More errors. Do I have to go back to Microsoft Windows?:
cloudwater@cloudwater-Alienware-15-R3:~$ sudo dpkg --configure -a
Setting up nvidia-340 (340.108-0ubuntu5.20.04.2) ...
dpkg: error: version '-' has bad syntax: revision number is empty
update-initramfs: deferring update (trigger activated)
INFO:Enable nvidia-340
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
Removing old nvidia-340-340.108 DKMS files...
Deleting module version: 340.108
completely from the DKMS tree.
Done.
Loading new nvidia-340-340.108 DKMS files...
Building for 5.11.0-27-generic
Building for architecture x86_64
Building initial module for 5.11.0-27-generic
Error! Bad return status for module build on kernel: 5.11.0-27-generic (x86_64)
Consult /var/lib/dkms/nvidia-340/340.108/build/make.log for more information.
dpkg: error processing package nvidia-340 (--configure):
installed nvidia-340 package post-installation script subprocess returned error exit status 10
dpkg: dependency problems prevent configuration of nvidia-331:
nvidia-331 depends on nvidia-340; however:
Package nvidia-340 is not configured yet.
dpkg: error processing package nvidia-331 (--configure):
Processing triggers for libc-bin (2.31-0ubuntu9.2) ...
Processing triggers for initramfs-tools (0.136ubuntu6.6) ...
update-initramfs: Generating /boot/initrd.img-5.11.0-27-generic
W: Possible missing firmware /lib/firmware/i915/skl_guc_49.0.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/bxt_guc_49.0.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/kbl_guc_49.0.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/glk_guc_49.0.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/cml_guc_49.0.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/icl_guc_49.0.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/ehl_guc_49.0.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/tgl_huc_7.5.0.bin for module i915
W: Possible missing firmware /lib/firmware/i915/tgl_guc_49.0.1.bin for module i915
W: Possible missing firmware /lib/firmware/i915/dg1_dmc_ver2_02.bin for module i915
nvidia-340
nvidia-331
Done.
E
cloudwater@cloudwater-Alienware-15-R3:~$ sudo apt-get install -f
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Done.
nvidia-340
nvidia-331
