Posts at category tutorials & guides
I think it would be good if posts in the "Tutorials & Guides" category couldn't simply be posted there by forum users, but instead, for example, a separate thread in another category was first created to introduce the tutorial with a request to publish it, and then the moderators would check to make sure everything is correct.
Recently it happened that newly registered users have posted risky scripts and programs there.
By the time it’s noticed and hidden or flagged with warnings, users may have already installed it on their system, assuming it had been reviewed and recommended, and then their system may be damaged.
Hello @Forpli,
I’m currently thinking about whether I should create a tutorial on ‘editing apt-Timer’:
You’ve put together an impressive amount of information there.
Do you already have any ideas on how you could put your suggestion into practice?
Sorry, I don't understand your question.
Would you like to know if you're allowed to create a tutorial about apt timer? Sure!
Or how to restrict access creating tutorials for normal users? For example, when creating a thread, you could no longer select the "Tutorials & Guides" category unless you belong to a specific group, such as the moderators.
Ah, I wasn’t clear enough, second attempt :face_with_hand_over_mouth:
As for my idea of creating a new tutorial, I thought I could use your new approach to put it into practice and refine it if necessary.
