Power Off prompt popping up a lot
Good night everyone, I'm dealing with an issue that is bothering me quite a bit. That "Power off" prompt that tells you the PC will shut off within 60s pops up from time to time here, and that would not be a huge deal if I were always close to the laptop. The thing is, sometimes that warning appears when I'm distant, the 60s countdown ends and the system shuts down. Any ideas on why I'm facing this? Thanks a lot.
Some machines have "Eco Mode". This can cause apparent random shutdowns.
You may also have a hardware fault that is causing the issue. Have you checked your Logs using LogViewer or journalctl?
It may be helpful if you give some basic system specs like if your processor is AMD, what your Graphics card is and so on.
