The blank screen after a set time is a useful feature. However, is there a way to not require my password to get past the blank screen?
Open terminal Ctl Alt F2.
Type the following code in terminal, and it should disable screen lock
gsettings set org.gnome.desktop.screensaver lock-enabled false
Perfect! Thank you so much.
