hello,
I cant seem to connect my bluetooth headset, clicking on bluetooth settings i can only see my mobile phone's bluetooth with a message reading visible as 'name' and available for file transfers. I can't see my headset's bluetooth I tried blueman but still got the same issue
any help is appreciated
Device: Dell Vostro 3491
additionally i installed bluetooth adaptor from software store which lead to my device recognizing a couple of extra bluetooth devices but not my headset
what exactly do i provide here as there is a bunch of information that i don't know what they mean?
Thanks
In Pavucontrol > Output devices > port - look for your device in the drop down menu.
You may have multiple Ports depending on your hardware. For example, audio over HDMI and audio over the built in stereo...
You mean, for sudo lshw -C network?
What we are checking there is the Radio Driver. Wifi and Bluetooth both use the Radio modules / Drivers. It can help to check the drivers for the radio device if Bluetooth is not working.
Look for description: Wireless interface
You want to relay product, vendor and configuration at least.
You can PM those details in a private message if you are confident in the member helping you in thread to prevent that information being publicly displayed.
in pavucontrol all i can see is device speaker and (unplugged)headphones I can configure that when i attach a wired headse, so I am guessing thats not the bluetooth headset, bluetooth headset still seems to not be connected.
