Problem with driver? (i think)
i have tried the activating and radeon from the recommended zorin os official website because originally brave stutters and glitches when i open it which led me to believe it was a driver problem. But i still feel like the system is stuttery and quite slow. I am new to linux and any help is appreciated
i have a AMD CPU with Radeon graphics and use the AMD Linux drivers
here is a link to the drivers and you want the drivers for Ubuntu x86 64-bit
https://www.amd.com/en/support/download/linux-drivers.html
best of luck Steve ..
Is your laptop one that has a nvidia vid card and the amd? cant see anything on it without serial numbers. I suspect it has an Nvidia card let us know i helped another who had simular trouble
Try it with disabling Hardware Acceleration in Brave. You can find it in the Brave Settings. Shouldn't You be able to find it or Brave should be too unstable, you can start Brave over the Terminal with disabled Hardware Acceleration with the Command:
brave-browser --disable-gpu
