After system update today Pcloud fails to open. The following message error appears:
Did you try to download the Appimage again ?
If you did an update try to do this:
sudo apt install libfuse2t64
I tried but got the following result:
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances... Fait
Lecture des informations d'état... Fait
E: Impossible de trouver le paquet libfuse2t64
Zorin 17 or Zorin 18 ?
Zorin 17.3 Pro
then try this
Le paquet est déjà installé
libfuse2 est déjà la version la plus récente (2.9.9-5ubuntu3).
0 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
Yes I did and it's ok now
but before to download the new AppImage I deleted:
- /home/current-user/.config/pcloud
- /home/current-user/.pcloud
- /home/current-user/.config/autostart/pcloud.desktop
- all the elements of "pcloud" downloaded previously (/home/downloads/pcloud)
Thank you very much for your help!
My pleasure ![]()
