Problem with updating zorin packages
Since three days, when I try to run the update manager or update with
sudo apt upgrade
I get this error:
E: Clearsigned file '/var/lib/apt/lists/ppa.launchpad.net_zorinos_apps_ubuntu_dists_focal_InRelease' contains unsigned lines.
E: The package lists or status file could not be parsed or opened.
and on system start I get an error icon in the task bar showing me the error message and telling me to
run Package Manager from the right-click menu or apt-get in a terminal to see what is wrong
and that
This usually means that your installed dependencies have unmet dependencies
But when I try to run the update manager nothing happens and apt-get doesn't tell me more.
What should I do?
What happens if you run
sudo apt --fix-broken install
It might also be that the mirrors are set to the wrong region (check in Software Updater > Settings > Zorin Software)
In my case, I ignore this error since it happens only when my time and date change much due to a persistent error and disappear once I restart the laptop or time and date are correct.
Can you open terminal and run
sudo rm -r /var/lib/apt/lists/*
sudo apt update
