Problems starting Zorin
Hello, I want to install Zorin OS Core but when I start boot with my USB, and I select "Try Zorin OS" the screen just goes black, I have already tried several times also flash the USB with the .iso, I have installed Cloud Ready (Chromium OS ) I hope someone can help me.
Hi and welcome to the Forum.
This has been discussed before. You may wish to take a look at this thread:
Sometimes, but not always, you may be able to close the try or install window by the x in the top right, and get into the live usb image that way. It may take a minute this way as well, so give it a chance before hard cycling the computer. I've experienced this on a good USB when i overwrote a windows image (it really doesn't play well with Linux). Hope this helps
