Problems updating (Misuse)
Hello everyone in the community. I need help because, once again, I ran into trouble while trying to install Docker. I followed a tutorial to install Docker via the terminal and used these commands.
sudo apt update
sudo apt install ca-certificates curl
sudo mkdir -p /etc/apt/keyrings
curl -fsSL https://download.docker.com/linux/debian/gpg
| sudo gpg --dearmor -o /etc/apt/keyrings/docker.gpg
echo "deb [arch=amd64 signed-by=/etc/apt/keyrings/docker.gpg]
Index of linux/debian/ $(lsb_release -cs) stable"
| sudo tee /etc/apt/sources.list.d/docker.list
sudo apt update
wget https://desktop.docker.com/linux/main/amd64/docker-desktop-latest-amd64.deb
sudo apt install ./docker-desktop-latest-amd64.deb
Besides not working, it's giving an error message when trying to update. This happens both through the update app and the device itself.
I apologize for once again damaging my system due to curiosity and carelessness!
1. Update your system
sudo apt update && sudo apt upgrade -y
2. Install required packages
sudo apt install apt-transport-https ca-certificates curl software-properties-common -y
3. Add Docker’s official GPG key
sudo curl -fsSL https://download.docker.com/linux/ubuntu/gpg -o /etc/apt/keyrings/docker.asc
sudo chmod a+r /etc/apt/keyrings/docker.asc
4. Add Docker APT repository
echo "deb [arch=$(dpkg --print-architecture) signed-by=/etc/apt/keyrings/docker.asc] https://download.docker.com/linux/ubuntu $(. /etc/os-release && echo "$VERSION_CODENAME") stable" | sudo tee /etc/apt/sources.list.d/docker.list > /dev/null
I need to restart the machine because running "docker version" still doesn't find it.
sudo apt install docker io
Do you have rustdesk instaled?
for remote support
you can go to software updates and remove all those docker repos in double
leave one from each needed from the original
Thank you, friend, and welcome. I managed to install and resolve the problems with the update apps. I even checked for duplicate entries. However, as in the image, there is a message: "permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get "http://%2Fvar%2Frun%2Fdocker.sock/v1.50/version": dial unix /var/run/docker.sock: connect: permission denied
" I don't have RustDesk....
Maybe this guide can help you:
Thank you all very much, it was just a matter of user configuration. Now everything is in order. @VBtech
