My problem is that I have a 3520 laptop with Zorin OS 17, a 480GB Adata SSD, 16GB of RAM, and a 10th generation i5 processor. With a new SSD, I'm trying to install Zorin 18, but I get errors during the installation. I put that SSD in a desktop PC and can install Zorin 18 correctly there. When I put that SSD back in my laptop, it gives an error. I try to format my laptop with Zorin 18, but I get boot errors. I've already tried changing the BIOS settings to legacy mode and all the options I found online and in forums. I feel like Zorin 18 has compatibility issues with laptops, but with Zorin 17 on the same PC, I don't have any problems. Help!
Can you please relay what errors are shown?
When you created the bootstick did you set as partition scheme GPT for uefi (MBR is used for legacy BIOS)?
What Tool did You use the create the bootable USB Stick?
