Quick Setting Tweaker
Quick Setting Tweaker is not working on zorin os 16
Could you provide some more context? Are you getting any errors? Do you have screenshots?
If youre using this extension -[QSTweak] Quick Setting Tweaker - GNOME Shell Extensions, it works only on 43+ gnome shell version. Zorin 16 doesnt come with 43 by default but you can install it.
To check your current gnome shell version, use this command - gnome-shell --version.
