Hello,there are still very few softwares that still tie me to windows and Radegast Viewer is one of those, for some time few years ago i had tried it in Garuda Linux Dragonized and was working fine, but it was made in aur if im not wrong, can someone make it in appimage or apt?
On their site they give the sourcecode, i really hope there is some good programmer that can make version for apt or appimage.
The whole site reads like it's (poorly) AI-generated to get your money, to be perfectly honest. The About Us section doesn't even match the people nor the description who appear in the GitHub page.
If you really want this for some reason, contact the developers, whoever they actually are.
PS: Removed link.
Hmmm hehe yes i noticed it only now because they did not have a site as i remember previously, i had sent a request to them already but it seems they are always busy fixing issues for the current windows version as my topic seem to have disappeared or maybe its there but i missed it damn me for not saving bookmark of it i created an other request today i hope they answer it soon, maybe the aur version is someone's else work, but the last time i used Garuda Linux was 3 years ago. I have also tried downloading the exe and starting it but at some point it gives me installation error in Bottles too.
I did grab the AUR .rpm file and converted it to a .deb, but ran into trouble with the fact that all that does is launch the .exe executable, then instruct that to utilize Wine.
Which... Zorin OS does automatically, anyway. This removes the necessity for the .deb or the .rpm.
Since you used it before this way, it seems likely you would be able to now. Just grab the .exe and run it on Zorin OS. At the prompt, install Zorin-Windows-App-Support to run the application Ragegast.
I already did that but it gives me this error while it tries to install net framework 48:
here is the content of the log hope to post it correctly:
[010C:0110][2025-05-28T12:51:30]i001: Burn x64 v6.0.0, Windows v10.0 x64 (Build 19043: Service Pack 0), path: Z:\home\user\Scaricati\RadegastSetup_x64-2.46.420.exe
[010C:0110][2025-05-28T12:51:30]i000: Initializing string variable 'InstallFolder' to value '[ProgramFiles64Folder]Radegast'
[010C:0110][2025-05-28T12:51:30]i009: Command Line: ''
[010C:0110][2025-05-28T12:51:30]i000: Setting string variable 'WixBundleOriginalSource' to value 'Z:\home\user\Scaricati\RadegastSetup_x64-2.46.420.exe'
[010C:0110][2025-05-28T12:51:30]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'Z:\home\user\Scaricati\'
[010C:0110][2025-05-28T12:51:30]i000: Setting string variable 'WixBundleLog' to value 'C:\users\user\Temp\Radegast_20250528125130.log'
[010C:0110][2025-05-28T12:51:30]i000: Setting string variable 'WixBundleInProgressName' to value ''
[010C:0110][2025-05-28T12:51:30]i000: Setting string variable 'WixBundleName' to value 'Radegast'
[010C:0110][2025-05-28T12:51:30]i000: Setting string variable 'WixBundleManufacturer' to value 'Sjofn, LLC'
[010C:0124][2025-05-28T12:51:30]i000: Setting version variable 'WixBundleFileVersion' to value '6.0.0.0'
[010C:0124][2025-05-28T12:51:30]i000: Setting numeric variable 'WixStdBAShowVersion' to value 1
[010C:0124][2025-05-28T12:51:30]i000: Setting numeric variable 'WixStdBALanguageId' to value 1033
[010C:0110][2025-05-28T12:51:30]i100: Detect begin, 2 packages
[010C:0110][2025-05-28T12:51:30]i000: Registry key not found. Key = 'SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full'
[010C:0110][2025-05-28T12:51:30]i052: Condition 'NETFRAMEWORK45 >= 528040' evaluates to false.
[010C:0110][2025-05-28T12:51:30]i101: Detected package: NetFx48Redist, state: Absent, cached: No, install registration state: (permanent), cache registration state: (permanent)
[010C:0110][2025-05-28T12:51:30]i101: Detected package: RadegastSetup, state: Absent, cached: No, install registration state: Absent, cache registration state: Absent
[010C:0110][2025-05-28T12:51:30]i199: Detect complete, result: 0x0, registration state: None, cached: No, eligible for cleanup: No
[010C:0124][2025-05-28T12:51:30]i052: Condition 'WixStdBAShowVersion' evaluates to true.
[010C:0124][2025-05-28T12:51:30]i052: Condition 'WixStdBAUpdateAvailable' evaluates to false.
[010C:0124][2025-05-28T12:51:30]i052: Condition 'NOT WixStdBASuppressOptionsUI' evaluates to true.
[010C:0110][2025-05-28T12:51:33]i200: Plan begin, 2 packages, action: Install
[010C:0110][2025-05-28T12:51:33]w321: Skipping dependency registration on package with no dependency providers: NetFx48Redist
[010C:0110][2025-05-28T12:51:33]i000: Setting string variable 'NetFx48RedistLog' to value 'C:\users\user\Temp\Radegast_20250528125130_000_NetFx48Redist.log'
[010C:0110][2025-05-28T12:51:33]i000: Setting string variable 'WixBundleRollbackLog_RadegastSetup' to value 'C:\users\user\Temp\Radegast_20250528125130_001_RadegastSetup_rollback.log'
[010C:0110][2025-05-28T12:51:33]i000: Setting string variable 'WixBundleLog_RadegastSetup' to value 'C:\users\user\Temp\Radegast_20250528125130_001_RadegastSetup.log'
[010C:0110][2025-05-28T12:51:33]i222: Planned rollback boundary: 'WixDefaultBoundary', vital: Yes, transaction: No (default: No)
[010C:0110][2025-05-28T12:51:33]i201: Planned package: NetFx48Redist, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, default cache strategy: Remove, ba requested strategy: Remove, cache: Vital, uncache: Yes, dependency: None, expected install registration state: (permanent), expected cache registration state: (permanent)
[010C:0110][2025-05-28T12:51:33]i201: Planned package: RadegastSetup, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, default cache strategy: Keep, ba requested strategy: Keep, cache: Vital, uncache: No, dependency: Register, expected install registration state: Present, expected cache registration state: Present
[010C:0110][2025-05-28T12:51:33]i299: Plan complete, result: 0x0
[010C:0110][2025-05-28T12:51:33]i300: Apply begin
[010C:0110][2025-05-28T12:51:33]i010: Launching elevated engine process.
[010C:0110][2025-05-28T12:51:33]i011: Launched elevated engine process.
[010C:0110][2025-05-28T12:51:34]i012: Connected to elevated engine.
[0130:0134][2025-05-28T12:51:34]i358: Pausing automatic updates.
[0130:0134][2025-05-28T12:51:34]i359: Paused automatic updates.
[0130:0134][2025-05-28T12:51:34]i360: Creating a system restore point.
[0130:0134][2025-05-28T12:51:34]i361: Created a system restore point.
[0130:0134][2025-05-28T12:51:34]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{94E6E17C-200D-4673-ACAE-626A0A09B066}, scope: PerMachine, options: 0x3, disable resume: No
[0130:0134][2025-05-28T12:51:34]i000: Caching bundle from: 'C:\windows\temp\{45BB9ADF-0798-475C-B896-E86A654D36E5}\.be\RadegastBundle_x64.exe' to: 'C:\ProgramData\Package Cache\{94E6E17C-200D-4673-ACAE-626A0A09B066}\RadegastBundle_x64.exe'
[0130:0134][2025-05-28T12:51:34]i320: Registering bundle dependency provider: {94E6E17C-200D-4673-ACAE-626A0A09B066}, version: 2.46.420.0
[0130:0134][2025-05-28T12:51:34]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{94E6E17C-200D-4673-ACAE-626A0A09B066}, scope: PerMachine, resume: Active, restart initiated: No, disable resume: No
[010C:014C][2025-05-28T12:51:34]i338: Acquiring package: NetFx48Redist, payload: NetFx48Redist, download from: https://go.microsoft.com/fwlink/?linkid=2088631
[0130:0148][2025-05-28T12:51:37]i305: Verified acquired payload: NetFx48Redist at path: C:\ProgramData\Package Cache\.unverified\NetFx48Redist, moving to: C:\ProgramData\Package Cache\NetFx48Redist_ABDCA79AF9DD48A0EA702AD45260B3C03093FB4B\redist\ndp48-x86-x64-allos-enu.exe.
[0130:0148][2025-05-28T12:51:37]i305: Verified acquired payload: RadegastSetup at path: C:\ProgramData\Package Cache\.unverified\RadegastSetup, moving to: C:\ProgramData\Package Cache\{1246CCB5-FFA1-4188-ACCB-36E4817C6102}v2.46.420.0\RadegastSetup_x64.msi.
[0130:0134][2025-05-28T12:51:37]i301: Applying execute package: NetFx48Redist, action: Install, path: C:\ProgramData\Package Cache\NetFx48Redist_ABDCA79AF9DD48A0EA702AD45260B3C03093FB4B\redist\ndp48-x86-x64-allos-enu.exe, arguments: '"C:\ProgramData\Package Cache\NetFx48Redist_ABDCA79AF9DD48A0EA702AD45260B3C03093FB4B\redist\ndp48-x86-x64-allos-enu.exe" /q /norestart /log "C:\users\user\Temp\Radegast_20250528125130_000_NetFx48Redist.log.html"'
[0130:0134][2025-05-28T12:52:08]i366: The process for package: NetFx48Redist exited with code: 0x0. The exit code has been translated to type: Success and restart: None.
[010C:0110][2025-05-28T12:52:08]i319: Applied execute package: NetFx48Redist, result: 0x0, restart: None
[0130:0134][2025-05-28T12:52:08]i323: Registering package dependency provider: {1246CCB5-FFA1-4188-ACCB-36E4817C6102}_v2.46.420.0, version: 2.46.420.0, package: RadegastSetup
[0130:0134][2025-05-28T12:52:08]i301: Applying execute package: RadegastSetup, action: Install, path: C:\ProgramData\Package Cache\{1246CCB5-FFA1-4188-ACCB-36E4817C6102}v2.46.420.0\RadegastSetup_x64.msi, arguments: ' INSTALLFOLDER="[ProgramFiles64Folder]Radegast" ARPSYSTEMCOMPONENT="1" MSIFASTINSTALL="7" BURNMSIINSTALL=1 REINSTALLMODE="muso" REBOOT=ReallySuppress'
[0130:0134][2025-05-28T12:52:08]e000: Error 0x80070643: Failed to install MSI package.
[010C:0110][2025-05-28T12:52:08]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[0130:0134][2025-05-28T12:52:08]e000: Error 0x80070643: Failed to execute MSI package.
[010C:0110][2025-05-28T12:52:08]i319: Applied execute package: RadegastSetup, result: 0x80070643, restart: None
[010C:0110][2025-05-28T12:52:08]e000: Error 0x80070643: Failed to execute MSI package.
[0130:0134][2025-05-28T12:52:08]i318: Skipped rollback of package: RadegastSetup, action: Uninstall, already: Absent
[010C:0110][2025-05-28T12:52:08]i319: Applied rollback package: RadegastSetup, result: 0x0, restart: None
[0130:0134][2025-05-28T12:52:08]i329: Removed package dependency provider: {1246CCB5-FFA1-4188-ACCB-36E4817C6102}_v2.46.420.0, package: RadegastSetup
[0130:0134][2025-05-28T12:52:08]i351: Removing cached package: RadegastSetup, from path: C:\ProgramData\Package Cache\{1246CCB5-FFA1-4188-ACCB-36E4817C6102}v2.46.420.0\
[0130:0134][2025-05-28T12:52:08]i351: Removing cached package: NetFx48Redist, from path: C:\ProgramData\Package Cache\NetFx48Redist_ABDCA79AF9DD48A0EA702AD45260B3C03093FB4B\
[010C:0110][2025-05-28T12:52:08]i373: Calculating whether to keep registration
[010C:0110][2025-05-28T12:52:08]i374: package: NetFx48Redist, install registration state: (permanent), cache registration state: (permanent)
[010C:0110][2025-05-28T12:52:08]i374: package: RadegastSetup, install registration state: Absent, cache registration state: Absent
[010C:0110][2025-05-28T12:52:08]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{94E6E17C-200D-4673-ACAE-626A0A09B066}, scope: PerMachine, resume: None, restart: None, disable resume: No, default registration: None, ba requested registration: None
[0130:0134][2025-05-28T12:52:08]i330: Removed bundle dependency provider: {94E6E17C-200D-4673-ACAE-626A0A09B066}
[0130:0134][2025-05-28T12:52:08]i326: Removed dependency: {94E6E17C-200D-4673-ACAE-626A0A09B066} on package provider: {1246CCB5-FFA1-4188-ACCB-36E4817C6102}_v2.46.420.0, package RadegastSetup
[0130:0134][2025-05-28T12:52:08]i352: Removing cached bundle: {94E6E17C-200D-4673-ACAE-626A0A09B066}, from path: C:\ProgramData\Package Cache\{94E6E17C-200D-4673-ACAE-626A0A09B066}\
[0130:0134][2025-05-28T12:52:08]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{94E6E17C-200D-4673-ACAE-626A0A09B066}, scope: PerMachine, resume: None, restart initiated: No, disable resume: No
[0130:0134][2025-05-28T12:52:08]i420: Resuming automatic updates.
[0130:0134][2025-05-28T12:52:08]i421: Resumed automatic updates.
[010C:0124][2025-05-28T12:52:08]i000: Setting string variable 'WixStdBARestartRequired' to value ''
[010C:0110][2025-05-28T12:52:08]i399: Apply complete, result: 0x80070643, restart: None, ba requested restart: No
[010C:0124][2025-05-28T12:52:08]i052: Condition 'WixBundleAction = 2' evaluates to false.
[010C:0124][2025-05-28T12:52:08]i052: Condition 'WixBundleAction = 3' evaluates to false.
[010C:0124][2025-05-28T12:52:08]i052: Condition 'WixBundleAction = 4' evaluates to false.
[010C:0124][2025-05-28T12:52:08]i052: Condition 'WixBundleAction = 5' evaluates to false.
[010C:0124][2025-05-28T12:52:08]i052: Condition 'WixBundleAction = 6' evaluates to true.
Formatted your post and re-uploaded the screenshot so that it's visible right away (you can upload images directly to the forum).
.NET Framework 48 was successfully installed:
Here, we see where Ragegast failed to install:
But it only gives the very generic Error 0x80070643 code which really could be anything...
You might need to ask on the WineHQ forums about specific dependency issues with Burn and Wine.
Burn is the software Bundle installer being used here.
Hmm im having issues registering there it gives me
"You have provided an invalid answer to the question.
You have exceeded the maximum number of registration attempts for this session. Please try again later."
Even when i give the right answer, i hope they fix it soon that so i can register there.
I managed to get through the installer using Bottles and sys-wine-10, but even when the install was (apparently) successful, Radagast wouldn't launch.
What if trying an earlier version of the software?
The Radegast website is... odd.
It has pretend Volunteers with rather comical descriptions and a "Lorem Ipsum" segment at the bottom.
I am not sure if that is humor or... something else. But it makes me question the stable maintenance of the software.
