Read only filesystem after installing Zorin18 on a macbook
Yes and you need to.
From LiveUSB:
sudo apt install smartmontools
sudo smartctl -a /dev/sda
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.14.0-37-generic] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Apple SD/SM/TS...E/F/G SSDs
Device Model:     APPLE SSD SM0256G
Serial Number:    S2Z5NY0HB06137
LU WWN Device Id: 5 002538 900000000
Firmware Version: BXZ13A0Q
User Capacity:    251,000,193,024 bytes [251 GB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    Solid State Device
TRIM Command:     Available
Device is:        In smartctl database 7.3/5528
ATA Version is:   ATA8-ACS T13/1699-D revision 4c
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Apr  4 21:54:52 2026 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
					Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(    0) seconds.
capabilities: 			 (0x53) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					No Offline surface scan supported.
					Self-test supported.
					No Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 (  10) minutes.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x001a   200   200   000    Old_age   Always       -       0
  5 Reallocated_Sector_Ct   0x0033   100   100   000    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0032   098   098   000    Old_age   Always       -       9812
 12 Power_Cycle_Count       0x0032   041   041   000    Old_age   Always       -       59161
169 Unknown_Apple_Attrib    0x0013   253   253   010    Pre-fail  Always       -       1481839215552
173 Wear_Leveling_Count     0x0032   176   176   100    Old_age   Always       -       2177596588603
174 Host_Reads_MiB          0x0022   099   099   000    Old_age   Always       -       66239019
175 Host_Writes_MiB         0x0022   099   099   000    Old_age   Always       -       49922245
192 Power-Off_Retract_Count 0x0012   099   099   000    Old_age   Always       -       139
194 Temperature_Celsius     0x0022   070   028   000    Old_age   Always       -       30 (Min/Max 13/72)
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
199 UDMA_CRC_Error_Count    0x001a   200   199   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
Warning! SMART Selective Self-Test Log Structure error: invalid SMART checksum.
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
  255        0    65535  Read_scanning was never started
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
The above only provides legacy SMART information - try 'smartctl -x' for more
I realize that S.M.A.R.T determined a PASS, but it actually did not pass all tests.
What the test shows us is that there are no NAND failures or Bad Blocks/Sectors.
In that regard, it passed. But, everything else shows really bad Firmware errors.
And this count is extremely high. It should be in the range of maybe 4,000, not nearly 60,000:
I definitely think this is the drive.
So I have to find another SSD then. I hope they're easy to change on a macbook.
Edit : I found a tutorial from iFixIt : Remplacement du SSD du MacBook Pro 15" Retina mi-2015 SSD - Tutoriel de réparation iFixit
I just have to find a compatible SSD because it seems there is a proprietary connector.
Are you able to avoid:
The drive itself is proprietary.
What do you mean ? If I find an SSD with this connector, then it will be compatible, won't it ?
I do not know off the top of my head... But the connector itself may be used across a variety of Apple drives.
Whereas the Drive Model Number:
APPLE SSD SM0256G is known to not work with Linux combined with the firmware.
I just installed Mint, and I was able to install things and use the disk as usual. But after two reboots I'm back to the initramfs invite.
Yes, I really think it is the drive after that S.M.A.R.T. result above. Those were pretty abnormal readings.
Thanks for the time you've put into this.
