root@zorin:~# sudo depmod -a
root@zorin:~# sudo modprobe r8821
modprobe: FATAL: Module r8821 not found in directory /lib/modules/5.15.0-56-generic
root@zorin:~# sudo modprobe r8821ce-dkms
modprobe: FATAL: Module r8821ce-dkms not found in directory /lib/modules/5.15.0-56-generic
root@zorin:~#
root@zorin:~# modprobe -r rtl8821ce
root@zorin:~# sudo apt remove --purge rtl8821ce-dkms
Reading package lists... Done
Building dependency tree
The following package was automatically installed and is no longer required:
dkms
Use 'sudo apt autoremove' to remove it.
The following packages will be REMOVED:
rtl8821ce-dkms*
0 upgraded, 0 newly installed, 1 to remove and 330 not upgraded.
After this operation, 25.2 MB disk space will be freed.
(Reading database ... 270158 files and directories currently installed.)
Removing rtl8821ce-dkms (5.5.2.1-0ubuntu4~20.04.5) ...
-------- Uninstall Beginning --------
Module: rtl8821ce
Version: 5.5.2.1
Kernel: 5.15.0-56-generic (x86_64)
Status: Before uninstall, this module version was ACTIVE on this kernel.
rtl8821ce.ko:
- Uninstallation
- Deleting from: /lib/modules/5.15.0-56-generic/updates/
- Original module
- No original module was found for this module on this kernel.
- Use the dkms install command to reinstall any previous module version.
/etc/modprobe.d/dkms.conf: removed 'blacklist rtw88_8821ce'
depmod...
DKMS: uninstall completed.
Deleting module version: 5.5.2.1
completely from the DKMS tree.
Done.
root@zorin:~#
zorin@zorin:~/Downloads$ cd rtw89-main
zorin@zorin:~/Downloads/rtw89-main$ make
make -C /lib/modules/5.15.0-56-generic/build M=/home/zorin/Downloads/rtw89-main modules
make[1]: Entering directory '/usr/src/linux-headers-5.15.0-56-generic'
CC [M] /home/zorin/Downloads/rtw89-main/core.o
CC [M] /home/zorin/Downloads/rtw89-main/chan.o
CC [M] /home/zorin/Downloads/rtw89-main/mac80211.o
CC [M] /home/zorin/Downloads/rtw89-main/mac.o
CC [M] /home/zorin/Downloads/rtw89-main/phy.o
CC [M] /home/zorin/Downloads/rtw89-main/fw.o
CC [M] /home/zorin/Downloads/rtw89-main/cam.o
CC [M] /home/zorin/Downloads/rtw89-main/efuse.o
CC [M] /home/zorin/Downloads/rtw89-main/regd.o
CC [M] /home/zorin/Downloads/rtw89-main/sar.o
CC [M] /home/zorin/Downloads/rtw89-main/acpi.o
CC [M] /home/zorin/Downloads/rtw89-main/coex.o
CC [M] /home/zorin/Downloads/rtw89-main/ps.o
CC [M] /home/zorin/Downloads/rtw89-main/debug.o
CC [M] /home/zorin/Downloads/rtw89-main/ser.o
CC [M] /home/zorin/Downloads/rtw89-main/wow.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw89core.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8852a.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8852a_table.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8852a_rfk.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8852a_rfk_table.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw_8852a.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8852ae.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw_8852ae.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8851b.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8851b_table.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8851b_rfk.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8851b_rfk_table.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw_8851b.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8851be.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw_8851be.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8852b.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8852b_table.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8852b_rfk.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8852b_rfk_table.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw_8852b.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8852be.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw_8852be.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8852c.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8852c_table.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8852c_rfk.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8852c_rfk_table.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw_8852c.o
CC [M] /home/zorin/Downloads/rtw89-main/rtw8852ce.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw_8852ce.o
CC [M] /home/zorin/Downloads/rtw89-main/pci.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw89pci.o
MODPOST /home/zorin/Downloads/rtw89-main/Module.symvers
CC [M] /home/zorin/Downloads/rtw89-main/rtw89core.mod.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw89core.ko
BTF [M] /home/zorin/Downloads/rtw89-main/rtw89core.ko
Skipping BTF generation for /home/zorin/Downloads/rtw89-main/rtw89core.ko due to unavailability of vmlinux
CC [M] /home/zorin/Downloads/rtw89-main/rtw89pci.mod.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw89pci.ko
BTF [M] /home/zorin/Downloads/rtw89-main/rtw89pci.ko
Skipping BTF generation for /home/zorin/Downloads/rtw89-main/rtw89pci.ko due to unavailability of vmlinux
CC [M] /home/zorin/Downloads/rtw89-main/rtw_8851b.mod.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw_8851b.ko
BTF [M] /home/zorin/Downloads/rtw89-main/rtw_8851b.ko
Skipping BTF generation for /home/zorin/Downloads/rtw89-main/rtw_8851b.ko due to unavailability of vmlinux
CC [M] /home/zorin/Downloads/rtw89-main/rtw_8851be.mod.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw_8851be.ko
BTF [M] /home/zorin/Downloads/rtw89-main/rtw_8851be.ko
Skipping BTF generation for /home/zorin/Downloads/rtw89-main/rtw_8851be.ko due to unavailability of vmlinux
CC [M] /home/zorin/Downloads/rtw89-main/rtw_8852a.mod.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw_8852a.ko
BTF [M] /home/zorin/Downloads/rtw89-main/rtw_8852a.ko
Skipping BTF generation for /home/zorin/Downloads/rtw89-main/rtw_8852a.ko due to unavailability of vmlinux
CC [M] /home/zorin/Downloads/rtw89-main/rtw_8852ae.mod.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw_8852ae.ko
BTF [M] /home/zorin/Downloads/rtw89-main/rtw_8852ae.ko
Skipping BTF generation for /home/zorin/Downloads/rtw89-main/rtw_8852ae.ko due to unavailability of vmlinux
CC [M] /home/zorin/Downloads/rtw89-main/rtw_8852b.mod.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw_8852b.ko
BTF [M] /home/zorin/Downloads/rtw89-main/rtw_8852b.ko
Skipping BTF generation for /home/zorin/Downloads/rtw89-main/rtw_8852b.ko due to unavailability of vmlinux
CC [M] /home/zorin/Downloads/rtw89-main/rtw_8852be.mod.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw_8852be.ko
BTF [M] /home/zorin/Downloads/rtw89-main/rtw_8852be.ko
Skipping BTF generation for /home/zorin/Downloads/rtw89-main/rtw_8852be.ko due to unavailability of vmlinux
CC [M] /home/zorin/Downloads/rtw89-main/rtw_8852c.mod.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw_8852c.ko
BTF [M] /home/zorin/Downloads/rtw89-main/rtw_8852c.ko
Skipping BTF generation for /home/zorin/Downloads/rtw89-main/rtw_8852c.ko due to unavailability of vmlinux
CC [M] /home/zorin/Downloads/rtw89-main/rtw_8852ce.mod.o
LD [M] /home/zorin/Downloads/rtw89-main/rtw_8852ce.ko
BTF [M] /home/zorin/Downloads/rtw89-main/rtw_8852ce.ko
Skipping BTF generation for /home/zorin/Downloads/rtw89-main/rtw_8852ce.ko due to unavailability of vmlinux
make[1]: Leaving directory '/usr/src/linux-headers-5.15.0-56-generic'
zorin@zorin:~/Downloads/rtw89-main$ sudo make install
Install rtw89 SUCCESS
zorin@zorin:~/Downloads/rtw89-main$ sudo mkdir /usr/lib/firmware/rtw89
mkdir: cannot create directory β/usr/lib/firmware/rtw89β: File exists
Also if I reboot , won't everything be lost? I'm running on Live USB, "Try Zorin", no persistence features enabled as far as I know.
That could explain our troubles... The LiveUSB falls back on the most generic drivers instead of reading your hardware and assigning the proper driver for that hardware.
[Just found out my cheap-as-chips KaiOS backup burner phone can do USB tethering, so hopefully I won't have to keep disconnecting like with my main phone.]
Thanks so much for all the tips you've given to help with this issue.
Is there a way to get the live USB to read the hardware and use the right driver? So that I can fully test & confirm Zorin Lite works on this hardware before I wipe Windows and install ZL?
Online info about installing driver for that card says computer has to reboot and doesn't seem to work with persistence, so I might have to go ahead and install ZL in order to try it. https://forums.linuxmint.com/viewtopic.php?t=392752
I'd really rather test this out on live and then do a whole disk install of ZL. But if there's no way to test it first live, then maybe I can dual boot until itΒΏs all working, then take over the whole disk.
OK, I researched how to enable persistence in Ventoy and I set it up.
I've tested it briefly. I changed the theme and wallpaper, and created two files. When I reboot with persistence, the changes to appearance do not persist, but the files I created do persist. Hopefully the driver-related stuff will persist.
Currently doing sudo apt update and will then try the other steps for installing drivers.
There have been so many steps in this thread I not sure which to do next. Maybe the ones here?
Although now I'm successfully tethered, maybe some of the steps are different? EDIT: E.g. can I use apt to get/ install the rtw89 driver or should I still manually download the zip from the website?
